A Small Scale Reflection Extension for the Coq system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This is the user manual of Ssreflect, a set of extensions to the proof scripting language of the Coq proof assistant. While these extensions were developed to support a particular proof methodology - small-scale reflection - most of them actually are of a quite general nature, improving the functionality of Coq in basic areas such as script layout and structuring, proof context management, and rewriting. Consequently, and in spite of the title of this document, most of the extensions described here should be of interest for all Coq users, whether they embrace small-scale reflection or not.
main.pdf (1.15 Mo) Télécharger le fichier
inria-00258384 , version 1 (21-02-2008)
inria-00258384 , version 2 (28-02-2008)
inria-00258384 , version 3 (27-07-2009)
inria-00258384 , version 4 (07-08-2009)
inria-00258384 , version 5 (21-02-2011)
inria-00258384 , version 6 (12-03-2011)
inria-00258384 , version 7 (15-03-2011)
inria-00258384 , version 8 (15-03-2011)
inria-00258384 , version 9 (16-03-2011)
inria-00258384 , version 10 (28-03-2011)
inria-00258384 , version 11 (05-09-2012)
inria-00258384 , version 12 (12-07-2013)
inria-00258384 , version 13 (21-02-2014)
inria-00258384 , version 14 (11-03-2014)
inria-00258384 , version 15 (08-04-2014)
inria-00258384 , version 16 (13-07-2015)
inria-00258384 , version 17 (03-11-2016)
  • HAL Id : inria-00258384 , version 14
Georges Gonthier, Assia Mahboubi, Enrico Tassi. A Small Scale Reflection Extension for the Coq system. [Research Report] RR-6455, 2008. ⟨inria-00258384v14⟩
8151 Consultations
6940 Téléchargements
