Visual servoing set free from image processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper proposes a new way to achieve robotic tasks by visual servoing. Instead of using geometric features (points, straight lines, pose, homography, etc.) as it is usually done, we use directly the luminance of all pixels in the image. Since most of the classical control laws fail in this case, we turn the visual servoing problem into an optimization problem leading to a new control law. Experimental results validate the proposed approach and show its robustness regarding to approximated depths, non Lambertian objects and partial occlusions.
Mots clés
2008_icra_collewet.pdf (530.87 Ko) Télécharger le fichier
inria-00261398 , version 1 (06-03-2008)
  • HAL Id : inria-00261398 , version 1
Christophe Collewet, Eric Marchand, François Chaumette. Visual servoing set free from image processing. IEEE Int. Conf. on Robotics and Automation, ICRA'08, IEEE, May 2008, Pasadena, United States. ⟨inria-00261398⟩
522 Consultations
381 Téléchargements
