Opacity Enforcing Control Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Given a finite transition system and a regular predicate, we address the problem of computing a controller enforcing the opacity of the predicate against an attacker (who partially observes the system), supposedly trying to push the system to reveal the predicate. Assuming that the controller can only control a subset of the events it observes (possibly different from the ones of the attacker), we show that an optimal control always exists and provide sufficient conditions under which it is regular and effectively computable. These conditions rely on the inclusion relationships between the controllable alphabet and the observable alphabets of the attacker and of the controller.
PI-1887.pdf (304.06 Ko) Télécharger le fichier
inria-00265855 , version 1 (20-03-2008)
inria-00265855 , version 2 (25-03-2008)
  • HAL Id : inria-00265855 , version 1
Jérémy Dubreil, Philippe Darondeau, Hervé Marchand. Opacity Enforcing Control Synthesis. [Research Report] PI 1887, 2008, pp.19. ⟨inria-00265855v1⟩
199 Consultations
208 Téléchargements
