Robust sliding mode control of nonlinear systems with delay: A design via polytopic formulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2004
This paper outlines the possibility to control nonlinear uncertain systems with single, possibly time-varying state-delay. These systems are submitted to additive perturbations (possibly nonvanishing). The control is of sliding mode type and the sliding surface is designed so to maximize the calculable set of delays which do not destabilize the system. The way to deal with the nonlinear parts of the model relies on a polytopic formulation. The conditions for the existence of the sliding regime are studied by using both a Lyapunov-Krasovskii functionnal and a Lyapunov-Razumikhin function. The optmization precedure for the choice of the sliding surface is expressed in terms of LMIs. An example illustrates the proposed method.
IJC2004-GBR.pdf (266.83 Ko) Télécharger le fichier
inria-00266509 , version 1 (23-03-2008)
Frédéric Gouaisbaut, Yann Blanco, Jean-Pierre Richard. Robust sliding mode control of nonlinear systems with delay: A design via polytopic formulation. International Journal of Control, 2004, 77 (2), pp.206-215. ⟨10.1080/00207170310001633286⟩. ⟨inria-00266509⟩
367 Consultations
297 Téléchargements
