From Random Graph to Small World by Wandering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Numerous studies show that most known real-world complex networks share similar properties in their connectivity and degree distribution. They are called small worlds. This article gives a method to turn random graphs into Small World graphs by the dint of random walks.
RR-6489.pdf (278.42 Ko) Télécharger le fichier
inria-00268788 , version 1 (01-04-2008)
inria-00268788 , version 2 (02-04-2008)
  • HAL Id : inria-00268788 , version 2
  • ARXIV : 0804.0149
Bruno Gaume, Fabien Mathieu. From Random Graph to Small World by Wandering. [Research Report] RR-6489, INRIA. 2008, pp.11. ⟨inria-00268788v2⟩
151 Consultations
184 Téléchargements
