Optimal control of the Primitive Equations of the Ocean with Lagrangian observations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We consider an optimal control problem for the three-dimensional non-linear Primitive Equations of the ocean in a vertically bounded and horizontally periodic domain. The observation operator maps a solution of the Primitive Equations to the trajectory of a Lagrangian particle. This paper proves the existence of an optimal control for the regularized problem. To do that, we prove also new energy estimates for the Primitive Equations, thanks to well-chosen functional spaces, which distinguish the vertical dimension from the horizontal ones. We illustrate the result with a numerical experiment.
rr-lag-ctrl.pdf (470.68 Ko) Télécharger le fichier
inria-00268804 , version 1 (01-04-2008)
inria-00268804 , version 2 (02-04-2008)
  • HAL Id : inria-00268804 , version 1
Maëlle Nodet. Optimal control of the Primitive Equations of the Ocean with Lagrangian observations. [Research Report] RR-6490, 2008, pp.25. ⟨inria-00268804v1⟩
237 Consultations
327 Téléchargements
