An efficient data structure to solve front propagation problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Scientific Computing Année : 2009
In this paper we develop a general efficient sparse storage technique suitable to coding front evolutions in d>= 2 space dimensions. This technique is mainly applied here to deal with deterministic target problems with constraints, and solve the associated minimal time problems. To this end we consider an Hamilton-Jacobi-Bellman equation and use an adapted anti-diffusive Ultra-Bee scheme. We obtain a general method which is faster than a full storage technique. We show that we can compute problems that are out of reach by full storage techniques (because of memory). Numerical experiments are provided in dimension d=2,3,4.
Preprint.pdf (525.97 Ko) Télécharger le fichier
inria-00273977 , version 1 (16-04-2008)
inria-00273977 , version 2 (22-10-2009)
Olivier Bokanowski, Emiliano Cristiani, Hasnaa Zidani. An efficient data structure to solve front propagation problems. Journal of Scientific Computing, 2009, ⟨10.1007/s10915-009-9329-6⟩. ⟨inria-00273977v1⟩
Collections
ENSTA
290 Consultations
405 Téléchargements
