True amplitude one-way propagation in heterogeneous media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This paper deals with the numerical analysis of two one-way systems derived from the general complete modeling proposed by M.V. De Hoop. The main goal of this work is to compare two different formulations in which a correcting term allows to improve the amplitude of the numerical solution. It comes out that even if the two systems are equivalent from a theoretical point of view, nothing of the kind is as far as the numerical simulation is concerned. Herein a numerical analysis is performed to show that as long as the propagation medium is smooth, both the models are equivalent but it is no more the case when the medium is associated to a quite strongly discontinuous velocity.
RR-6517.pdf (539.19 Ko) Télécharger le fichier
inria-00274885 , version 1 (21-04-2008)
inria-00274885 , version 2 (16-07-2008)
  • HAL Id : inria-00274885 , version 2
  • ARXIV : 0804.3975
Hélène Barucq, Bertrand Duquet, Frank Prat. True amplitude one-way propagation in heterogeneous media. [Research Report] RR-6517, INRIA. 2008, pp.37. ⟨inria-00274885v2⟩
308 Consultations
162 Téléchargements
