Fine-grained parallelization of similarity search between protein sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This report presents the implementation of a protein sequence comparison algorithm specifically designed for speeding up time consuming part on parallel hardware such as SSE instructions, multicore architectures or graphic boards. Three programs have been developed: PLAST-P, TPLAST-N and PLAST-X. They provide equivalent results compared to the NCBI BLAST family programs (BLAST-P, TBLAST-N and BLAST-X) with a speed-up factor ranging from 5 to 10.
rapport_recherche.pdf (529.81 Ko) Télécharger le fichier
inria-00275250 , version 1 (23-04-2008)
inria-00275250 , version 2 (23-04-2008)
  • HAL Id : inria-00275250 , version 1
  • ARXIV : 0804.3643
van Hoa Nguyen, Dominique Lavenier. Fine-grained parallelization of similarity search between protein sequences. [Research Report] 2008, pp.40. ⟨inria-00275250v1⟩
190 Consultations
150 Téléchargements
