Metaheuristics and Their Hybridization to Solve the Bi-objective Ring Star Problem: a Comparative Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This paper presents and experiments approaches to solve a new bi-objective routing problem called the ring star problem. It consists of locating a simple cycle through a subset of nodes of a graph while optimizing two kinds of cost. The first objective is the minimization of a ring cost that is related to the length of the cycle. The second one is the minimization of an assignment cost from non-visited nodes to visited ones. In spite of its obvious bi-objective formulation, this problem has always been investigated in a single-objective way. To tackle the bi-objective ring star problem, we first investigate different stand-alone search methods. Then, we propose two cooperative strategies that combines two multiple objective metaheuristics: an elitist evolutionary algorithm and a population-based local search. We apply this new hybrid approaches to well-known benchmark test instances and demonstrate their effectiveness in comparison to non-hybrid algorithms and to state-of-the-art methods.
liefooghe.rr08a.pdf (660.93 Ko) Télécharger le fichier
inria-00275659 , version 1 (24-04-2008)
inria-00275659 , version 2 (28-04-2008)
  • HAL Id : inria-00275659 , version 1
  • ARXIV : 0804.3965
Arnaud Liefooghe, Laetitia Jourdan, El-Ghazali Talbi. Metaheuristics and Their Hybridization to Solve the Bi-objective Ring Star Problem: a Comparative Study. [Research Report] 2008. ⟨inria-00275659v1⟩
Collections
LIFL
161 Consultations
138 Téléchargements
