Isosurface extraction and interpretation on very large datasets in geophysics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In order to deal with the heavy trend in size increase of volumetric datasets, research in isosurface extraction has focused in the past few years on related aspects such as surface simplification and load balanced parallel algorithms. We present in this paper a parallel, bloc-wise extension of the tandem algorithm [Attali et al. 2005], which simplifies on the fly an isosurface being extracted. Our approach minimizes the overall memory consumption using an adequate bloc splitting and merging strategy and with the introduction of a component dumping mechanism that drastically reduces the amount of memory needed for particular datasets such as those encountered in geophysics. As soon as detected, surface components are migrated to the disk along with a meta-data index (oriented bounding box, volume, etc) that will allow further improved exploration scenarios (small components removal or particularly oriented components selection for instance). For ease of implementation, we carefully describe a master and slave algorithm architecture that clearly separates the four required basic tasks. We show several results of our parallel algorithm applied on a 7000×1600×2000 geophysics dataset.
ACM_SPM_08_Isosurface_Extraction_in_Geophysics.pdf (4.3 Mo) Télécharger le fichier
inria-00277070 , version 1 (05-05-2008)
  • HAL Id : inria-00277070 , version 1
Guilhem Dupuy, Bruno Jobard, Sébastien Guillon, Noomane Keskes, Dimitri Komatitsch. Isosurface extraction and interpretation on very large datasets in geophysics. ACM Solid and Physical Modeling Symposium, Jun 2008, New York, United States. ⟨inria-00277070⟩
584 Consultations
236 Téléchargements
