Sketch and Paint-based Interfacefor Highlight Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2008
In computer graphics, highlights capture much of the appearance of light reflection off a surface. They are generally limited to pre-defined models (e.g., Phong, Blinn) or to measured data. In this paper, we introduce new tools and a corresponding highlight model to provide computer graphics artists a more expressive approach to design highlights. For each defined light key-direction, the artist simply sketches and paints the main highlight features (shape, intensity, and color) on a plane oriented perpendicularly to the reflected direction. For other light-andview configurations, our system smoothly blends the different user-defined highlights. Based on GPU abilities, our solution allows real-time editing and feedback. We illustrate our approach with a wide range of highlights, with complex shapes and varying colors. This solution also demonstrates the simplicity of introduced tools
Keywords
main.pdf (2.86 Mo) Télécharger le fichier
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Dates and versions
inria-00277102 , version 1 (05-05-2008)
Identifiers
Cite
Romain Pacanowski, Xavier Granier, Christophe Schlick, Poulin Pierre. Sketch and Paint-based Interfacefor Highlight Modeling. Fifth Eurographics conference on Sketch-Based Interfaces and Modeling, Jun 2008, Annecy, France. ⟨10.2312/SBM/SBM08/017-023⟩. ⟨inria-00277102⟩
Relations
322 View
206 Download
Share
