On rough differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Probability Année : 2008
We prove that the Ito map, that is the map that gives the solution of a differential equation controlled by a rough path of finite p-variation with p in [2,3) is locally Lipschitz continuous in all its arguments and could be extended to vector fields that have only a linear growth.
lejay-rde-2008.pdf (169.52 Ko) Télécharger le fichier
inria-00278246 , version 1 (09-05-2008)
inria-00278246 , version 2 (20-12-2008)
inria-00278246 , version 3 (03-02-2009)
  • HAL Id : inria-00278246 , version 1
Antoine Lejay. On rough differential equations. Electronic Journal of Probability, 2008. ⟨inria-00278246v1⟩
195 Consultations
283 Téléchargements
