Parallel Pricing Algorithms for Multi--Dimensional Bermudan/American Options using Monte Carlo methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this paper we present two parallel Monte Carlo based algorithms for pricing multi--dimensional Bermudan/American options. First approach relies on computation of the optimal exercise boundary while the second relies on classification of continuation and exercise values. We also evaluate the performance of both the algorithms in a desktop grid environment. We show the effectiveness of the proposed approaches in a heterogeneous computing environment, and identify scalability constraints due to the algorithmic structure.
Rapport.pdf (399.06 Ko) Télécharger le fichier
inria-00278514 , version 1 (13-05-2008)
inria-00278514 , version 2 (13-05-2008)
  • HAL Id : inria-00278514 , version 1
  • ARXIV : 0805.1827
Mireille Bossy, Françoise Baude, Viet Dung Doan, Abhijeet Gaikwad, Ian Stokes-Rees. Parallel Pricing Algorithms for Multi--Dimensional Bermudan/American Options using Monte Carlo methods. [Research Report] 2008, pp.16. ⟨inria-00278514v1⟩
270 Consultations
377 Téléchargements
