Mesh Repair with Topology Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this research report, we propose a new method to convert a triangular mesh with geometrical and topological defects into a 2-manifold, whose topology (genus and number of connected components) is controlled by the user. We start by converting the input mesh into a thin layer of face-connected voxels; then the topology of this voxel set can be modified by the user thanks to morphological operators of different orders; at last the fixed voxel set is converted back into a triangular mesh, which both is a 2-manifold and have the desired topology.
rr-mesh_repair.pdf (1.25 Mo) Télécharger le fichier
inria-00279919 , version 1 (15-05-2008)
inria-00279919 , version 2 (15-05-2008)
inria-00279919 , version 3 (18-01-2010)
  • HAL Id : inria-00279919 , version 1
Franck Hétroy, Stéphanie Rey, Carlos Andujar, Pere Brunet, Alvar Vinacua. Mesh Repair with Topology Control. [Research Report] RR-6535, 2008, pp.23. ⟨inria-00279919v1⟩
253 Consultations
359 Téléchargements
