Software Architecture Patterns for a Context-Processing Middleware Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Distributed Systems Online Année : 2008
Ubiquitous applications are characterised by variations of their execution context. Their correct operation requires some continual adaptations based on the observation of their execution context. The design and the implementation of these observation policies is then the cornerstone of any ubiquitous applications. In this article, we propose COSMOS which is a framework for the principled specification and composition of context observation policies. With COSMOS, these policies are decomposed into fine-grained units called \emph{context nodes} implemented as software components. These units perform basic context-related operations (\emph{e.g.}, gathering data from a system or network probe, computing threshold or average values) and are assembled with a set of well-identified architectural design patterns. In this article, COSMOS is motivated and illustrated with an example from the domain of mobile e-commerce applications.
article.pdf (106.6 Ko) Télécharger le fichier
inria-00286616 , version 1 (10-06-2008)
Romain Rouvoy, Denis Conan, Lionel Seinturier. Software Architecture Patterns for a Context-Processing Middleware Framework. IEEE Distributed Systems Online, 2008, 9 (6), pp.1-13. ⟨10.1109/MDSO.2008.17⟩. ⟨inria-00286616⟩
224 Consultations
630 Téléchargements
