Adaptive Encoding: How to Render Search Coordinate System Invariant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper describes a method for rendering search coordinate system independent, Adaptive Encoding. Adaptive Encoding is applicable to any iterative search algorithm and employs incremental changes of the representation of solutions. One attractive way to change the representation in the continuous domain is derived from Covariance Matrix Adaptation (CMA). In this case, adaptive encoding recovers the CMA evolution strategy, when applied to an evolution strategy with cumulative step-size control. Consequently, adaptive encoding provides the means to apply CMA-like representation changes to any search algorithm in the continuous domain. Experimental results confirm the expectation that CMA-based adaptive encoding will generally speed up a typical evolutionary algorithm on non-separable, ill-conditioned problems by orders of magnitude.
ppsn2008.pdf (372.65 Ko) Télécharger le fichier
inria-00287351 , version 1 (11-06-2008)
inria-00287351 , version 2 (23-06-2008)
inria-00287351 , version 3 (23-06-2008)
  • HAL Id : inria-00287351 , version 3
Nikolaus Hansen. Adaptive Encoding: How to Render Search Coordinate System Invariant. Parallel Problem Solving from Nature - PPSN X, Sep 2008, Dortmund, Germany. pp.205-214. ⟨inria-00287351v3⟩
1009 Consultations
857 Téléchargements
