Distributed and Incremental Clustering Based on Weighted Affinity Propagation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Cyril Furtlehner
  • Fonction : Auteur
  • PersonId : 849672
Michèle Sebag
  • Fonction : Auteur
  • PersonId : 836537
A new clustering algorithm Affinity Propagation (AP) is hindered by its quadratic complexity. The Weighted Affinity Propagation (WAP) proposed in this paper is used to eliminate this limitation, support two scalable algorithms. Distributed AP clustering handles large datasets by merging the exemplars learned from subsets. Incremental AP extends AP to online clustering of data streams. The paper validates all proposed algorithms on benchmark and on real-world datasets. Experimental results show that the proposed approaches offer a good trade-off between computational effort and performance.
STAIRS08_vfinal.pdf (121.2 Ko) Télécharger le fichier
inria-00287378 , version 1 (11-06-2008)
  • HAL Id : inria-00287378 , version 1
Xiangliang Zhang, Cyril Furtlehner, Michèle Sebag. Distributed and Incremental Clustering Based on Weighted Affinity Propagation. the fourth European Starting AI Researcher Symposium (STAIRS), Jul 2008, Patras, Greece. ⟨inria-00287378⟩
123 Consultations
362 Téléchargements
