Commande sans modèle et commande à modèle restreint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue e-STA Sciences et Technologies de l’Automatique Année : 2008
We are introducing a model-free control and a control with a restricted model for finite-dimensional complex systems. This control design may be viewed as a contribution to ``intelligent'' PID controllers, the tuning of which becomes quite easy, even with highly nonlinear and/or time-varying systems. Our main tool is a newly developed numerical differentiator. Differential algebra provides the theoretical framework. Our approach is validated by several numerical experiments.
esta_sans.modele.pdf (1.5 Mo) Télécharger le fichier
inria-00288107 , version 1 (28-06-2008)
inria-00288107 , version 2 (28-06-2008)
inria-00288107 , version 3 (01-02-2009)
  • HAL Id : inria-00288107 , version 3
Michel Fliess, Cédric Join. Commande sans modèle et commande à modèle restreint. e-STA Sciences et Technologies de l’Automatique, 2008, 5 (4), pp.1-23. ⟨inria-00288107v3⟩
2076 Consultations
3049 Téléchargements
