The computability path ordering: the end of a quest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper, we first briefly survey automated termination proof methods for higher-order calculi. We then concentrate on the higher-order recursive path ordering, for which we provide an improved definition, the Computability Path Ordering. This new definition appears indeed to capture the essence of computability arguments à la Tait and Girard, therefore explaining the name of the improved ordering.
main.pdf (152.17 Ko) Télécharger le fichier
inria-00288209 , version 1 (16-06-2008)
inria-00288209 , version 2 (16-06-2008)
  • HAL Id : inria-00288209 , version 2
  • ARXIV : 0806.2517
Frédéric Blanqui, Jean-Pierre Jouannaud, Albert Rubio. The computability path ordering: the end of a quest. 7th EACSL Annual Conference on Computer Science Logic - CSL'08, Sep 2008, Bertinoro, Italy. ⟨inria-00288209v2⟩
460 Consultations
314 Téléchargements
