Interaction Grammars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Interaction Grammar (IG) is a grammatical formalism based on the notion of polarity. Polarities express the resource sensitivity of natural languages by modelling the distinction between saturated and unsaturated syntactic structures. Syntactic composition is represented as a chemical reaction guided by the saturation of polarities. It is expressed in a model-theoretic framework where grammars are constraint systems using the notion of tree description and parsing appears as a process of building tree description models satisfying criteria of saturation and minimality.
rr_ig.pdf (335.24 Ko) Télécharger le fichier
inria-00288376 , version 1 (16-06-2008)
inria-00288376 , version 2 (02-09-2008)
  • HAL Id : inria-00288376 , version 1
Bruno Guillaume, Guy Perrier. Interaction Grammars. [Research Report] 2008, pp.29. ⟨inria-00288376v1⟩
151 Consultations
228 Téléchargements
