Tilting at windmills with Coq: formal verification of a compilation algorithm for parallel moves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Automated Reasoning Année : 2008
This article describes the formal verification of a compilation algorithm that transforms parallel moves (parallel assignments between variables) into a semantically-equivalent sequence of elementary moves. Two different specifications of the algorithm are given: an inductive specification and a functional one, each with its correctness proofs. A functional program can then be extracted and integrated in the Compcert verified compiler.
parallel-move.pdf (185.32 Ko) Télécharger le fichier
inria-00289709 , version 1 (23-06-2008)
Laurence Rideau, Bernard P. Serpette, Xavier Leroy. Tilting at windmills with Coq: formal verification of a compilation algorithm for parallel moves. Journal of Automated Reasoning, 2008, 40 (4), pp.307-326. ⟨10.1007/s10817-007-9096-8⟩. ⟨inria-00289709⟩
261 Consultations
267 Téléchargements
