Proximity of Persistence Modules and their Diagrams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Frédéric Chazal
David Cohen-Steiner
  • Fonction : Auteur
  • PersonId : 833472
Leonidas J. Guibas
  • Fonction : Auteur
  • PersonId : 850076
Steve Oudot
  • Fonction : Auteur correspondant
  • PersonId : 845393
Connectez-vous pour contacter l'auteur
Topological persistence has proven to be a key concept for the study of real-valued functions defined over topological spaces. Its validity relies on the fundamental property that the persistence diagrams of nearby functions are close. However, existing stability results are restricted to the case of continuous functions defined over triangulable spaces. In this paper, we present new stability results that do not suffer from the above restrictions. Furthermore, by working at an algebraic level directly, we make it possible to compare the persistence diagrams of functions defined over different spaces, thus enabling a variety of new applications of the concept of persistence. Along the way, we extend the definition of persistence diagram to a larger setting, introduce the notions of discretization of a persistence module and associated pixelization map, define a proximity measure between persistence modules, and show how to interpolate between persistence modules, thereby lending a more analytic character to this otherwise algebraic setting. We believe these new theoretical concepts and tools shed new light on the theory of persistence, in addition to simplifying proofs and enabling new applications.
RR-6568.pdf (465.11 Ko) Télécharger le fichier
inria-00292566 , version 1 (05-07-2008)
inria-00292566 , version 2 (26-11-2008)
inria-00292566 , version 3 (27-11-2008)
inria-00292566 , version 4 (28-11-2008)
  • HAL Id : inria-00292566 , version 3
Frédéric Chazal, David Cohen-Steiner, Marc Glisse, Leonidas J. Guibas, Steve Oudot. Proximity of Persistence Modules and their Diagrams. [Research Report] RR-6568, 2008, pp.28. ⟨inria-00292566v3⟩
823 Consultations
1606 Téléchargements
