A Model for the Mixed-Design of Data-Intensive and Control-Oriented Embedded Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This paper presents a model and its semantics for the design of embedded systems that contain data-intensive parts such as multimedia applications, and require adaptivity w.r.t. criteria such as platform resources or quality of service (QoS). The proposed solution relies on a combination of: i) the repetitive model of computation dedicated to the design of high-performance embedded systems and ii) reactive control features based on finite state machines and modes. It is defined within a framework, called Gaspard, that implements automatic transformations that lead to various target languages, e.g., synchronous languages, SystemC, VHDL. The new model offers the adequate expressive power to describe complex behaviors of high-performance embedded systems. It also reconciles execution models dedicated to regular computations and control-oriented models that rather lead to irregular computations.
RRcontrol.pdf (491.94 Ko) Télécharger le fichier
inria-00293909 , version 1 (07-07-2008)
inria-00293909 , version 2 (23-07-2008)
  • HAL Id : inria-00293909 , version 1
Abdoulaye Gamatié, Eric Rutten, Huafeng Yu. A Model for the Mixed-Design of Data-Intensive and Control-Oriented Embedded Systems. [Research Report] 2008, pp.26. ⟨inria-00293909v1⟩
247 Consultations
140 Téléchargements
