Analysis of Scalar Fields over Point Cloud Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Frédéric Chazal
Leonidas J. Guibas
  • Fonction : Auteur
  • PersonId : 850076
Steve Y. Oudot
  • Fonction : Auteur correspondant
  • PersonId : 845393
Connectez-vous pour contacter l'auteur
Primoz Skraba
  • Fonction : Auteur
  • PersonId : 850314
Given a real-valued function f defined over some metric space X, is it possible to recover some structural information about f from the sole information of its values at a finite set L of sample points, whose pairwise distances in X are given? We provide a positive answer to this question. More precisely, taking advantage of recent advances on the front of stability for persistence diagrams, we introduce a novel algebraic construction, based on a pair of nested families of simplicial complexes built on top of the point cloud L, from which the persistence diagram of f can be faithfully approximated. We derive from this construction a series of algorithms for the analysis of scalar fields from point cloud data. These algorithms are simple and easy to implement, they have reasonable complexities, and they come with theoretical guarantees. To illustrate the genericity and practicality of the approach, we also present some experimental results obtained in various applications, ranging from clustering to sensor networks.
RR-6576.pdf (1.64 Mo) Télécharger le fichier
inria-00294591 , version 1 (09-07-2008)
inria-00294591 , version 2 (18-03-2009)
inria-00294591 , version 3 (21-04-2009)
  • HAL Id : inria-00294591 , version 1
Frédéric Chazal, Leonidas J. Guibas, Steve Y. Oudot, Primoz Skraba. Analysis of Scalar Fields over Point Cloud Data. [Research Report] RR-6576, 2008. ⟨inria-00294591v1⟩
Collections
INRIA-RRRT
365 Consultations
887 Téléchargements
