Robust curvature extrema detection based on new numerical derivation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Extrema of curvature are useful key points for different image analysis tasks. Indeed, polygonal approximation or arc decomposition methods used often these points to initialize or to improve their algorithms. Several shape-based image retrieval methods focus also their descriptors on key points. This paper is focused on the detection of extrema of curvature points for a raster-to-vector-conversion framework. We propose an original adaptation of an approach used into nonlinear control for fault-diagnosis and fault-tolerant control based on algebraic derivation and which is robust to noise. The experimental results are promising and show the robustness of the approach when the contours are bathed into a high level speckled noise.
Automatique
acivs_revised_final.pdf (371.3 Ko) Télécharger le fichier
inria-00300799 , version 1 (20-07-2008)
  • HAL Id : inria-00300799 , version 1
Cédric Join, Salvatore Tabbone. Robust curvature extrema detection based on new numerical derivation. Advanced Concepts for Intelligent Vision Systems, ACIVS 2008, Oct 2008, Juan-les-Pins, France. ⟨inria-00300799⟩
560 Consultations
224 Téléchargements
