Optimal importance sampling for tracking in image sequences: application to point tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Élise Arnaud
Etienne Mémin
  • Fonction : Auteur
  • PersonId : 952791
In this paper, we propose a particle filtering technique for tracking applications in image sequences. The system we propose combines a measurement equation and a dynamic equation which both depend on the image sequence. Taking into account several possible observations, the peculiar measure model we consider is a linear combination of Gaussian laws. Such a model allows us to infer an analytic expression of the optimal importance function used in the diffusion process of the particle filter. We demonstrate the significance of this model for a point tracking application. The resulting point tracker enables coping with trajectories undergoing abrupt changes, occlusion situations, large geometric deformations and noisy sequences. Its performances are shown on real world sequences.
Eccv04Arnaud.pdf (392.01 Ko) Télécharger le fichier
Format : Figure, Image
inria-00306725 , version 1 (03-04-2009)
  • HAL Id : inria-00306725 , version 1
Élise Arnaud, Etienne Mémin. Optimal importance sampling for tracking in image sequences: application to point tracking. IEEE European conference on computer vision, 2004, Prague, Czech Republic. ⟨inria-00306725⟩
149 Consultations
116 Téléchargements
