multiobjective optimization in hydrodynamic stability control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We focus on a shape optimization problem in hydrodynamic stability control. The goal is to minimize the drag in a flow regime by modification of the underlying geometry while ensuring hydrodynamic stability. We propose an extension of a numerical scheme to speed up the computations and avoid the solving of the original PDE model. Therefore, a metamodel is used as approximation of the original model. A Particle Swarm Optimization algorithm is used in conjunction with a Nash game to consider both objectives simultaneously, with a split of design variables established from a sensitivity analysis accounting for first and second derivatives of functionals related to the metamodel.
RR-6608.pdf (276.7 Ko) Télécharger le fichier
inria-00309693 , version 1 (07-08-2008)
  • HAL Id : inria-00309693 , version 1
Frank Strauss, Jean-Antoine Desideri, Régis Duvigneau, Vincent Heuveline. multiobjective optimization in hydrodynamic stability control. [Research Report] RR-6608, INRIA. 2008. ⟨inria-00309693⟩
144 Consultations
110 Téléchargements
