A Reduced Basis Approach for Variational Problems with Stochastic Parameters: Application to Heat Conduction with Variable Robin Coefficient - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this work, a Reduced Basis (RB) approach is used to solve a large number of Boundary Value Problems (BVPs) parametrized by a stochastic input — expressed as a Karhunen-Loève expansion — in order to compute outputs that are smooth functionals of the random solution fields. The RB method proposed here for variational problems parametrized by stochastic coefficients bears many similarities to the RB approach developed previously for deterministic systems. However, the stochastic framework requires the development of new a posteriori estimates for “statistical” outputs — such as the first two moments of integrals of the random solution fields; these error bounds, in turn, permit efficient sampling of the input stochastic parameters and fast reliable computation of the outputs in particular in the many-query context.
SPDE_final.pdf (651.51 Ko) Télécharger le fichier
inria-00311463 , version 1 (18-08-2008)
  • HAL Id : inria-00311463 , version 1
Sébastien Boyaval, Claude Le Bris, Yvon Maday, Ngoc Cuong Nguyen, Anthony T. Patera. A Reduced Basis Approach for Variational Problems with Stochastic Parameters: Application to Heat Conduction with Variable Robin Coefficient. [Research Report] RR-6617, INRIA. 2008, pp.50. ⟨inria-00311463⟩
255 Consultations
321 Téléchargements
