An impossibility result for process discrimination - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2008
Daniil Ryabko
  • Function : Author
  • PersonId : 848126
Two series of binary observations $x_1,x_1,\dots$ and $y_1,y_2,\dots$ are presented: at each time $n\in\N$ we are given $x_n$ and $y_n$. It is assumed that the sequences are generated independently of each other by two B-processes. We are interested in the question of whether the sequences represent a typical realization of two different processes or of the same one. We demonstrate that this is impossible to decide, in the sense that every discrimination procedure is bound to err with non-negligible frequency when presented with sequences from some B-processes. This contrasts earlier positive results on B-processes, in particular those showing that there are consistent $\bar d$-distance estimates for this class of processes.
discr.pdf (140.64 Ko) Télécharger le fichier
Dates and versions
inria-00319076 , version 1 (05-09-2008)
inria-00319076 , version 2 (11-01-2009)
inria-00319076 , version 3 (11-01-2009)
inria-00319076 , version 4 (08-05-2009)
inria-00319076 , version 5 (09-05-2009)
inria-00319076 , version 6 (09-05-2009)
inria-00319076 , version 7 (10-07-2009)
Identifiers
  • HAL Id : inria-00319076 , version 1
  • ARXIV : 0809.1053
Cite
Daniil Ryabko. An impossibility result for process discrimination. [Research Report] 2008. ⟨inria-00319076v1⟩
158 View
189 Download
Share
