Ray-traced collision detection for deformable bodies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper presents a new approach to collision detection and modeling between deformable volumetric bod- ies. It allows deep intersections while alleviating the difficulties of distance field update. A ray is shot from each surface vertex in the direction of the inward normal. A collision is detected when the first intersection be- longs to an inward surface triangle of another body. A contact force between the vertex and the matching point is then created. Experiments show that this approach is fast and more robust than traditional proximity-based collisions.
grapp08.pdf (227.78 Ko) Télécharger le fichier
TorusCyl.avi (226.52 Ko) Télécharger le fichier
chain.avi (758.75 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00319404 , version 1 (09-09-2008)
inria-00319404 , version 2 (15-07-2010)
  • HAL Id : inria-00319404 , version 2
Everton Hermann, François Faure, Bruno Raffin. Ray-traced collision detection for deformable bodies. GRAPP 2008 - 3rd International Conference on Computer Graphics Theory and Applications, Jan 2008, Madeira, Portugal. pp.293-299. ⟨inria-00319404v2⟩
545 Consultations
1095 Téléchargements
