Using linear programming duality for solving finite horizon Dec-POMDPs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2008
Raghav Aras
  • Fonction : Auteur
  • PersonId : 830439
Alain Dutech
This paper studies the problem of finding an optimal finite horizon joint policy for a decentralized partially observable Markov decision process (Dec-POMDP). We present a new algorithm for finding an optimal joint policy. The algorithm is based on the fact that the necessary condition for a joint policy to be optimal is that it be locally optimal (that is, a Nash equilibrium). Through the application of linear programming duality, the necessary condition can be transformed to a nonlinear program which can then further be transformed to a 0-1 mixed integer linear program (MILP) whose optimal solution is an optimal joint policy (in the sequence form). The proposed algorithm thus consists of solving this 0-1 MILP. Computational experience of the 0-1 MILP on two and three agent DEC-POMDPs gives mixed results. On some problems it is faster than existing algorithms, on others it is slower.
RR-6641.pdf (185.79 Ko) Télécharger le fichier
inria-00320645 , version 1 (16-09-2008)
  • HAL Id : inria-00320645 , version 1
Raghav Aras, Alain Dutech, François Charpillet. Using linear programming duality for solving finite horizon Dec-POMDPs. [Technical Report] RR-6641, INRIA. 2008, pp.27. ⟨inria-00320645⟩
154 Consultations
140 Téléchargements
