Automatic Face Naming with Caption-based Supervision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Thomas Mensink
  • Fonction : Auteur
  • PersonId : 853681
Jakob Verbeek
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
We consider two scenarios of naming people in databases of news photos with captions: (i) finding faces of a single person, and (ii) assigning names to all faces. We combine an initial text-based step, that restricts the name assigned to a face to the set of names appearing in the caption, with a second step that analyzes visual features of faces. By searching for groups of highly similar faces that can be associated with a name, the results of purely text-based search can be greatly ameliorated. We improve a recent graph-based approach, in which nodes correspond to faces and edges connect highly similar faces. We introduce constraints when optimizing the objective function, and propose improvements in the low-level methods used to construct the graphs. Furthermore, we generalize the graph-based approach to face naming in the full data set. In this multi-person naming case the optimization quickly becomes computationally demanding, and we present an important speed-up using graph-flows to compute the optimal name assignments in documents. Generative models have previously been proposed to solve the multi-person naming task. We compare the generative and graph-based methods in both scenarios, and find significantly better performance using the graph-based methods in both cases.
verbeek08cvpr.pdf (1.7 Mo) Télécharger le fichier
GMVS08.poster.pdf (911.88 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00321048 , version 1 (25-01-2011)
inria-00321048 , version 2 (11-04-2011)
Matthieu Guillaumin, Thomas Mensink, Jakob Verbeek, Cordelia Schmid. Automatic Face Naming with Caption-based Supervision. CVPR 2008 - IEEE Conference on Computer Vision & Pattern Recognition, Jun 2008, Anchorage, United States. pp.1-8, ⟨10.1109/CVPR.2008.4587603⟩. ⟨inria-00321048v2⟩
386 Consultations
1939 Téléchargements
