Semi-supervised dimensionality reduction using pairwise equivalence constraints
To deal with the problem of insufficient labeled data, usually side information -- given in the form of pairwise equivalence constraints between points -- is used to discover groups within data. However, existing methods using side information typically fail in cases with high-dimensional spaces. In this paper, we address the problem of learning from side information for high-dimensional data. To this end, we propose a semi-supervised dimensionality reduction scheme that incorporates pairwise equivalence constraints for finding a better embedding space, which improves the performance of subsequent clustering and classification phases. Our method builds on the assumption that points in a sufficiently small neighborhood tend to have the same label. Equivalence constraints are employed to modify the neighborhoods and to increase the separability of different classes. Experimental results on high-dimensional image data sets show that integrating side information into the dimensionality reduction improves the clustering and classification performance.
Apprentissage [cs.LG]
verbeek08cvta.pdf (1.13 Mo)
Télécharger le fichier
CVJK08.poster.pdf (936.38 Ko)
Format : Figure, Image
Format : Autre
