Semi-supervised learning with Gaussian fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2005
Jakob Verbeek
Nikos Vlassis
  • Fonction : Auteur
  • PersonId : 853678
Gaussian fields (GF) have recently received considerable attention for dimension reduction and semi-supervised classification. This paper presents two contributions. First, we show how the GF framework can be used for regression tasks on high-dimensional data. We consider an active learning strategy based on entropy minimization and a maximum likelihood model selection method. Second, we show how a recent generalization of the Locally Linear Embedding algorithm for correspondence learning can also be cast into the GF framework, which obviates the need to choose a representation dimensionality.
verbeek05tr.pdf (507.73 Ko) Télécharger le fichier
Format : Figure, Image
inria-00321480 , version 1 (25-01-2011)
inria-00321480 , version 2 (05-04-2011)
  • HAL Id : inria-00321480 , version 2
Jakob Verbeek, Nikos Vlassis. Semi-supervised learning with Gaussian fields. [Technical Report] IAS-UVA-05, 2005, pp.20. ⟨inria-00321480v2⟩
Collections
LARA
116 Consultations
127 Téléchargements
