Gaussian mixture learning from noisy data - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Technical Report) Year : 2004
Nikos Vlassis
  • Function : Author
  • PersonId : 853678
Jakob Verbeek
We address the problem of learning a Gaussian mixture from a set of noisy data points. Each input point has an associated covariance matrix that can be interpreted as the uncertainty by which this point was observed. We derive an EM algorithm that learns a Gaussian mixture that minimizes the Kullback-Leibler divergence to a variable kernel density estimator on the input data. The proposed algorithm performs iterative optimization of a strict bound on the Kullback-Leibler divergence, and is provably convergent.
verbeek04tr.pdf (86.51 Ko) Télécharger le fichier
Format : Figure, Image
Dates and versions
inria-00321483 , version 1 (02-02-2011)
inria-00321483 , version 2 (05-04-2011)
Identifiers
  • HAL Id : inria-00321483 , version 2
Cite
Nikos Vlassis, Jakob Verbeek. Gaussian mixture learning from noisy data. [Technical Report] IAS-UVA-04, 2004, pp.6. ⟨inria-00321483v2⟩
Collections
LARA
154 View
219 Download
Share
