Coordinating principal component analyzers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Jakob Verbeek
Nikos Vlassis
  • Fonction : Auteur
  • PersonId : 853678
Mixtures of Principal Component Analyzers can be used to model high dimensional data that lie on or near a low dimensional manifold. By linearly mapping the PCA subspaces to one global low dimensional space, we obtain a 'global' low dimensional coordinate sys- tem for the data. As shown by Roweis et al., ensuring consistent global low-dimensional coordinates for the data can be expressed as a penal- ized likelihood optimization problem. We show that a restricted form of the Mixtures of Probabilistic PCA model allows for a more efficient algorithm. Experimental results are provided to illustrate the viability method.
verbeek02icann.pdf (251.77 Ko) Télécharger le fichier
Format : Figure, Image
inria-00321498 , version 1 (16-02-2011)
Jakob Verbeek, Nikos Vlassis, Ben Krose. Coordinating principal component analyzers. International Conference on Artificial Neural Networks (ICANN '02), Aug 2002, Madrid, Spain. ⟨10.1007/3-540-46084-5_148⟩. ⟨inria-00321498⟩
109 Consultations
225 Téléchargements
