The generative self-organizing map: a probabilistic generalization of Kohonen's SOM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2002
Jakob Verbeek
Nikos Vlassis
  • Fonction : Auteur
  • PersonId : 853678
Ben Krose
  • Fonction : Auteur
  • PersonId : 853721
We present a variational Expectation-Maximization algorithm to learn proba- bilistic mixture models. The algorithm is similar to Kohonen's Self-Organizing Map algorithm and can be applied on any mixture model for which we can find a standard Expectation Maximization algorithm. We maximize the variational free- energy which sums data log-likelihood and Kullback-Leibler divergence between the neighborhood function and the posterior distribution on the components, given data. We illustrate the algorithm with an application on word clustering.
verbeek02tr.pdf (164.81 Ko) Télécharger le fichier
Format : Figure, Image
inria-00321505 , version 1 (16-02-2011)
  • HAL Id : inria-00321505 , version 1
Jakob Verbeek, Nikos Vlassis, Ben Krose. The generative self-organizing map: a probabilistic generalization of Kohonen's SOM. [Technical Report] IAS-UVA-02-03, 2002. ⟨inria-00321505⟩
Collections
LARA
168 Consultations
724 Téléchargements
