The global k-means clustering algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2001
Aristidis Likas
  • Fonction : Auteur
  • PersonId : 853723
Nikos Vlassis
  • Fonction : Auteur
  • PersonId : 853678
Jakob Verbeek
We present the global k-means algorithm which is an incremental approach to clustering that dynamically adds one cluster at a time through a deterministic global search procedure consisting of N (with N being the size of the data set) executions of the k-means algorithm from suitable initial positions. We also propose modifications of the methods to reduce the computational load without significantly affecting solution quality. The proposed clustering methods are tested on well-known data sets and they compare favorably to the k-means algorithm with random restarts.
verbeek01tr.pdf (216.05 Ko) Télécharger le fichier
Format : Figure, Image
inria-00321515 , version 1 (16-02-2011)
  • HAL Id : inria-00321515 , version 1
Aristidis Likas, Nikos Vlassis, Jakob Verbeek. The global k-means clustering algorithm. [Technical Report] IAS-UVA-01-02, 2001, pp.12. ⟨inria-00321515⟩
Collections
LARA
497 Consultations
16386 Téléchargements
