Distributed Management of Massive Data: an Efficient Fine-Grain Data Access Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper addresses the problem of efficiently storing and accessing massive data blocks in a large-scale distributed environment, while providing efficient fine-grain access to data subsets. This issue is crucial in the context of applications in the field of databases, data mining and multimedia. We propose a data sharing service based on distributed, RAM-based storage of data, while leveraging a DHT-based, natively parallel metadata management scheme. As opposed to the most commonly used grid storage infrastructures that provide mechanisms for explicit data localization and transfer, we provide a transparent access model, where data are accessed through global identifiers. Our proposal has been validated through a prototype implementation whose preliminary evaluation provides promising results.
paper.pdf (345.21 Ko) Télécharger le fichier
inria-00323248 , version 1 (12-10-2008)
Bogdan Nicolae, Gabriel Antoniu, Luc Bougé. Distributed Management of Massive Data: an Efficient Fine-Grain Data Access Scheme. VECPAR '08: Proceedings of the 8th International Conference on High Performance Computing for Computational Science, Jun 2008, Toulouse, France. pp.532-543, ⟨10.1007/978-3-540-92859-1_47⟩. ⟨inria-00323248⟩
178 Consultations
246 Téléchargements
