Piecewise Planar Modeling for Step Detection using Stereo Vision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
A mobility aid for the visually impaired should be able to detect and warn about nearby obstacles. Reliable detection of curbs and steps is critical to meet this goal. This paper describes a stereo-vision based algorithm that estimates the underlying planar geometry of the 3D scene to generate hypotheses for the presence of steps. Tensor voting is used to calculate globally consistent normals at each data point and a clustering algorithm is described to generate a piecewise planar model of the scene. Results demonstrate the improvement in plane clustering using tensor voting and the ability of the algorithm to find sufficient evidence for the presence of curbs and steps.
PiecewisePlanarModeling.pdf (451.36 Ko) Télécharger le fichier
inria-00325448 , version 1 (29-09-2008)
  • HAL Id : inria-00325448 , version 1
Vivek Pradeep, Gerard Medioni, James Weiland. Piecewise Planar Modeling for Step Detection using Stereo Vision. Workshop on Computer Vision Applications for the Visually Impaired, James Coughlan and Roberto Manduchi, Oct 2008, Marseille, France. ⟨inria-00325448⟩
Collections
CVAVI08
328 Consultations
292 Téléchargements
