Approximate RBF Kernel SVM and Its Applications in Pedestrian Classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper presents an efficient approximation to the nonlinear SVM with Radial Basis Function (RBF) kernel. By employing second-order polynomial approximation to RBF kernel, the derived approximate RBF-kernel SVM classifier can take a compact form by exchanging summation in conventional SVM classification formula, leading to constant low complexity that is only relevant to the dimensions of feature. Experiments on pedestrian classification show that our approximate RBF-kernel SVM achieved classification performance close to the exact implementation with significantly low time and memory.
mlvma08_submission_5.pdf (146.88 Ko) Télécharger le fichier
inria-00325810 , version 1 (30-09-2008)
  • HAL Id : inria-00325810 , version 1
Hui Cao, Takashi Naito, Yoshiki Ninomiya. Approximate RBF Kernel SVM and Its Applications in Pedestrian Classification. The 1st International Workshop on Machine Learning for Vision-based Motion Analysis - MLVMA'08, Oct 2008, Marseille, France. ⟨inria-00325810⟩
Collections
MLVMA08
1199 Consultations
4021 Téléchargements
