Simultaneous Learning and Alignment: Multi-Instance and Multi-Pose Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In object recognition in general and in face detection in particular, data alignment is necessary to achieve good classification results with certain statistical learning approaches such as Viola-Jones. Data can be aligned in one of two ways: (1) by separating the data into coherent groups and training separate classifiers for each; (2) by adjusting training samples so they lie in correspondence. If done manually, both procedures are labor intensive and can significantly add to the cost of labeling. In this paper we present a unified boosting framework for simultaneous learning and alignment. We present a novel boosting algorithm for Multiple Pose Learning (mpl), where the goal is to simultaneously split data into groups and train classifiers for each. We also review Multiple Instance Learning (mil), and in particular mil-boost, and describe how to use it to simultaneously train a classifier and bring data into correspondence. We show results on variations of LFW and MNIST, demonstrating the potential of these approaches.
BabenkoEtAlECCV08simul.pdf (868.07 Ko) Télécharger le fichier
inria-00326736 , version 1 (05-10-2008)
  • HAL Id : inria-00326736 , version 1
Boris Babenko, Piotr Dollár, Zhuowen Tu, Serge Belongie. Simultaneous Learning and Alignment: Multi-Instance and Multi-Pose Learning. Workshop on Faces in 'Real-Life' Images: Detection, Alignment, and Recognition, Erik Learned-Miller and Andras Ferencz and Frédéric Jurie, Oct 2008, Marseille, France. ⟨inria-00326736⟩
Collections
REALFACES2008
589 Consultations
398 Téléchargements
