An Efficient Lagrangian Relaxation for the Contact Map Overlap Problem - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2008
Among the measures for quantifying the similarity between protein 3-D structures, contact map overlap (CMO) maximization deserved sustained attention during past decade. Despite this large involvement, the known algorithms possess a modest performance and are not applicable for large scale comparison. This paper offers a clear advance in this respect. We present a new integer programming model for CMO and propose an exact B&B algorithm with bounds obtained by a novel Lagrangian relaxation. The efficiency of the approach is demonstrated on a popular small benchmark (Skolnick set, 40 domains). On this set our algorithm significantly outperforms the best existing exact algorithms. Many hard CMO instances have been solved for the first time. To assess furthermore our approach, we constructed a large scale set of 300 protein domains. Computing the similarity measure for any of the 44850 couples, we obtained a classification in excellent agreement with SCOP.
wabi_08.pdf (227.17 Ko) Télécharger le fichier
Dates and versions
inria-00327135 , version 1 (07-10-2008)
Identifiers
Cite
Rumen Andonov, Nicola Yanev, Noël Malod-Dognin. An Efficient Lagrangian Relaxation for the Contact Map Overlap Problem. WABI 2008 (8th Workshop on Algorithms in Bioinformatics), Universität Karlsruhe, Sep 2008, Karlsruhe, Germany. pp.162-173, ⟨10.1007/978-3-540-87361-7_14⟩. ⟨inria-00327135⟩
159 View
468 Download
Share
