Wind projection basis for real-time animation of trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This scientific report presents a real-time method to animate complex scenes of thousands of trees under a user-controllable wind load. Firstly, modal analysis is applied to extract the main modes of deformation from the mechanical model of a 3D tree. The novelty of our contribution is to precompute a new basis of the modal stress of the tree under wind load. At runtime, this basis allows to replace the modal projection of the external forces by a direct mapping for any directional wind. We show that this approach can be efficiently implemented on a graphics hardware. This modal animation can be simulated at low computation cost even for large scenes containing thousands of trees.
RR-6674.pdf (1004.59 Ko) Télécharger le fichier
inria-00328122 , version 1 (14-10-2008)
inria-00328122 , version 2 (21-10-2008)
  • HAL Id : inria-00328122 , version 1
Julien Diener, Mathieu Rodriguez, Lionel Baboud, Lionel Reveret. Wind projection basis for real-time animation of trees. [Research Report] RR-6674, 2008, pp.20. ⟨inria-00328122v1⟩
Collections
INRIA-RRRT
1180 Consultations
2765 Téléchargements
