Discovering Phrases in Machine Translation by Simulated Annealing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper, we propose a new phrase-based translation model based on inter-lingual triggers. The originality of our method is double. First we identify common source. Then we use inter-lingual triggers in order to retrieve their translat ions. Furthermore, we consider the way of extracting phrase trans- lations as an optimization issue. For that we use simulated annealing algorithm to find out the best phrase translations among all those determined by inter-lingual triggers. The best phrases are those which improve the translation quality in terms of Bleu score. Tests are achieved on the proceedings of the European Parliament corpora. The training is made on a corpus containing 596K parallel sentences (French-English) and tests on a corpus of 1444 sentences. With only 8.1% of the identified source phrases occurring in the test corpus, our system overcomes the baseline model by almost 3 points.
CarolineLavecchia.pdf (69.12 Ko) Télécharger le fichier
inria-00331327 , version 1 (16-10-2008)
  • HAL Id : inria-00331327 , version 1
Caroline Lavecchia, David Langlois, Kamel Smaïli. Discovering Phrases in Machine Translation by Simulated Annealing. INTERSPEECH 2008 - 9th Annual Conference of the International Speech Communication Association, Sep 2008, Brisbane, Australia. pp.2354-2357. ⟨inria-00331327⟩
141 Consultations
234 Téléchargements
