Helly-type theorems for approximate covering - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2008
Let F \cup {U} be a collection of convex sets in R^d such that F covers U. We prove that if the elements of F and U have comparable size then a small subset of F suffices to cover most of the volume of U; we analyze how small this subset can be depending on the geometry of the elements of F, and show that smooth convex sets and axis parallel squares behave differently. We obtain similar results for surface-to-surface visibility amongst balls in 3 dimensions for a notion of volume related to form factor. For each of these situations, we give an algorithm that takes F and U as input and computes in time O(|F|*|h_e|)$ either a point in U not covered by F or a subset h_e covering U up to a measure e, with |h_e| meeting our combinatorial bounds.
AppCovering.pdf (237.7 Ko) Télécharger le fichier
Dates and versions
inria-00331435 , version 1 (16-10-2008)
Identifiers
  • HAL Id : inria-00331435 , version 1
Cite
Julien Demouth, Olivier Devillers, Marc Glisse, Xavier Goaoc. Helly-type theorems for approximate covering. SoCG 2008 - 24th Annual Symposium on Computational Geometry, Jun 2008, College Park, Maryland, United States. pp.120--128. ⟨inria-00331435⟩
266 View
152 Download
Share
