Multi-Site Emulation using Wrekavoc: Validating Distributed Algorithms and Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Olivier Dubuisson
  • Fonction : Auteur
  • PersonId : 854812
Jens Gustedt
Emmanuel Jeannot
Experimental validation and testing of solutions designed for heterogeneous environment is a challenging issue. Wrekavoc is a tool for performing such validation. It runs an unmodified applications on emulated multisite heterogeneous platforms. It downgrades the performance of the nodes (CPU and memory) and the interconnection network in a prescribed way. We report on new strategies to improve the accuracy of the network and memory models. Then, we present an experimental validation of the tool that compares executions of a variety of application code. The comparison is done between a real heterogeneous platform against the emulation of that platform with Wrekavoc. The measurements show that our approach allows for a close reproduction of the real measurements in the emulator.
RR-wrekavoc.pdf (1.16 Mo) Télécharger le fichier
inria-00331627 , version 1 (21-10-2008)
  • HAL Id : inria-00331627 , version 1
Olivier Dubuisson, Jens Gustedt, Emmanuel Jeannot. Multi-Site Emulation using Wrekavoc: Validating Distributed Algorithms and Applications. [Research Report] RR-6696, INRIA. 2008, 30 p. ⟨inria-00331627⟩
204 Consultations
134 Téléchargements
