Satisfiability Procedures for Combination of Theories Sharing Integer Offsets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We present a novel technique to combine satisfiability procedures for theories that model some data-structures and that share the integer offsets. This procedure extends the Nelson-Oppen approach to a family of non-disjoint theories that have practical interest in verification. The result is derived by showing that the considered theories satisfy the hypotheses of a general result on non-disjoint combination. In particular, the capability of computing logical consequences over the shared signature is ensured in a non trivial way by devising a suitable complete superposition calculus.
RR-6697.pdf (351.09 Ko) Télécharger le fichier
inria-00331735 , version 1 (17-10-2008)
inria-00331735 , version 2 (27-04-2009)
  • HAL Id : inria-00331735 , version 1
Enrica Nicolini, Christophe Ringeissen, Michael Rusinowitch. Satisfiability Procedures for Combination of Theories Sharing Integer Offsets. [Research Report] RR-6697, 2008, pp.22. ⟨inria-00331735v1⟩
Collections
INRIA-RRRT
155 Consultations
177 Téléchargements
