3D Wavelet Sub-Bands Mixing for Image Denoising - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Biomedical Imaging Année : 2008
A critical issue in image restoration is the problem of noise removal while keeping the integrity of relevant image information. The method proposed in this paper is a fully automatic 3D blockwise version of the Non Local (NL) Means filter with wavelet sub-bands mixing. The proposed wavelet sub-bands mixing is based on a multi-resolution approach for improving the quality of image denoising filter. Quantitative validation was carried out on synthetic datasets generated with the BrainWeb simulator. The results show that our NL-means filter with wavelet sub-bands mixing outperforms the classical implementation of the NL-means filter in terms of denoising quality and computation time. Comparison with well- established methods, such as non linear diffusion filter and total variation minimization, shows that the proposed NL-means filter produces better denoising results. Finally, qualitative results on real data are presented.
Coupe08a.pdf (2.15 Mo) Télécharger le fichier
inria-00332001 , version 1 (20-10-2008)
Pierrick Coupé, Pierre Hellier, Sylvain Prima, Charles Kervrann, Christian Barillot. 3D Wavelet Sub-Bands Mixing for Image Denoising. International Journal of Biomedical Imaging, 2008, 2008 (Article ID 590183), pp.590183. ⟨10.1155/2008/590183⟩. ⟨inria-00332001⟩
281 Consultations
239 Téléchargements
